Coloring of syntax in SSH sessions
@James Julier : The best solution is to use the overrides. This will apply to all connexions.
@Branko Zavrl : i’m looking for the same thing
What happens that text Highlighting is so slow? A few milliseconds pass before it is applied to the screen. Is there any way to improve this speed?
the delay for the text highlighting is a known issue and there’s not much we can do. I’m sorry. The issue is, that we are using a third party control (from Rebex.net) which doesn’t have this feature baked into the product. So we need to “scrape” the screen once the updates are done and do the highlighting manually ourselves.
You can tweak the delay in the plugin settings but choosing a timespan too short, may result in undesirable behavior:
