In Custom Properties when you need to change order och delete a lot of fields it’s not that easy to do this one by one.
*If there was a mode to “drag n drop” for changing the order in the fields that would be nice, now you need to “Move field up” a lot of times, to get it to the top (If I have 10-15 fields it’s time consuming).
**Also, when I need to delete a lot of fields it would be nice to have a tickbox for which fields should be deleted, then “delete all” (button) would be very nice.
