The Current beta for TSX is missing the copy to clipboard option that was there in the previous version. Was there in the previous version. (26.0.10)
Hello Agboola,
I’ve just checked this in the latest Royal TSX V26 Beta 10 and for me, when in the SSH tab, the Copy to Clipboard option can be found in the Actions tab as shown here:
Can you please elaborate on how to replicate the issue so I can look into this again?
Thanks & best regards,
So when i initially launch. It usually gives me then especially if i throw it into full screen. It just happens and the next time i check it’s all okay. I usually find it hard to replicate. But it happens.
I know it isn’t related, but is there putty support on Mac OS now for TSX?
This has been fixed internally and will be part of the next beta release. Please note however that the “Actions” menu is not tied to the selected tab. Instead, it acts on the selection in the navigation panel or dashboard, depending on what’s active or has last been active. Usually (by default), the navigation panel selection is synced with the selected tab but that is something that can be deactivated in the app settings.
