I would like to request enhancement to the existing AWS import with an option to specify temporary AWS credentials which contains the AWS_SESSION_TOKEN.
Hi Nasir,
while we don’t support that specific scenario at the moment, you should check out our new “Dynamic Folder” feature which also allows you to dynamically import connections from AWS.
We have a sample script in our toolbox repository which you can customize and, of course, also use AWS_SESSION_TOKEN.
Check it out here: https://www.royalapplications.com/go/dynamicfolder-samples
