As we are getting more and more into our document. In the way of connections and credentials we would like to have to option to start typing for a credential and that RoyalTSX gives the suggestions with what it finds in the document (or Documents).
Ab for example should than show all records with ab in it:
A fast growing list example of our credentials:
And these are not all. We need to add about 1000 more, so you can imagine the list of credentials and picking the right one is very odd with a long list.
So autocomplete / search will be very helpful.
This can now be done with specify credential, but!!
If you change the name of the credential it does not work. And that works with Select a Credential from the list since its linked to I think the ID or something so if you change the name it will not f*ck it all up
But still work.
Felix also liked the idea
so Thumbs up!
