Would it be difficult to have a task built-in that could be activated which would query a connection port for the connection type (I use RDP for all servers) and connect when the port is open? I know DameWare does something similar on their port and I have a powershell script I can use that checks 3389 on a server and opens mstsc when it is available but it would be nice to not have to check servers every coule minutes after a reboot to see if I can get in yet, and ping is not a good enough indicator.
Jason
Hi Jason,
thank you for the feedback. This is definitely on our to-do list! I hope we can implement that once the initial V4 is released.
Hello, is it already integrated? Thank you Filip
Hi Filip,
not yet, but it’s still on our list.
Hi, is it now integrated? That would be really helpful.
Hi Joerg,
yes, if you setup Royal TS to leave remotely disconnected tabs open, it will try to reconnect automatically:
https://docs.royalapps.com/r2023/royalts/reference/options.html#keep-remotely-disconnected-tabs-open
