I have found a couple of similar topics but none seem exactly the same. This is for RoyalTS in Windows.
Currently it is possible to right-click a web-page(Chrome)-type object, and select Connect with Options > Open in Default Browser.
Could this same functionality be added to the object properties > Window Mode > Open connection in: “External App - Default Browser” - so that double-clicking an item will default to open in the external browser app? Ideally I’d think to be able to be set in the app defaults as well.
I have just worked out that (per another similar request from 7 years ago) that using a cmd task, specifying the browser .exe and using the $URI$ parameter will allow right-click > Command Tasks > “Open in Edge Browser” (my task) also works quite nicely.
Still finding my way around RoyalTS.
Thank you for the awesome product ![]()
