Allow batch operations for changing settings from many entries at a time
I noticed that in Royal TS V5, there is no way to select multiple entries and configure settings across all of them with a single method. Is there a way to add the ability to configure settings if similar entries (such as only RDP objects) are selected, and then show up one window to configure settings once to apply to all entries?
For existing objects, you can use the bulk-edit feature to edit all connections at once
https://www.royalapplications.com/go/kb-ts-win-folderdashboard
https://www.royalapplications.com/go/kb-ts-win-bulkedit
Hello Stefan,
Yes, this was the feature I was looking for. I did not realize that it was built-in to the middle pane. I guess I was overlooking it this whole time. Thank you for pointing me in the right direction.
Glad I could help, Steven!
