All the settings explained for default.settings.json
Do you have any documents explaining all the settings we can set with default.settings.json and initial.settigs.json?
I would like to see what settings I can set in my Citrix image.
Hi Jim,
you can find most of the application options here:
https://docs.royalapps.com/r2023/scripting/objects/options/royalapplicationsetting.html
Some options are not documented. In this case, you can simply change the configuration in the app and look at the code4ward.RoyalTS.UserPreferences.config file to see the name of the option and the value.
You can also find all the available object properties here:
https://docs.royalapps.com/r2023/scripting/objects/index.html
I hope this helps.
