Can external applications be added to TSX like it is for TS (https://docs.royalapps.com/r2021/royalts/reference/connections/external-app.html)?
Hi Chris,
no, external applications are not supported by Royal TSX. The reason is that macOS doesn’t allow windows of other applications to be “re-parented” like on Windows.
You can however use Command Tasks to launch external applications. To do so, create a new Command Task, enter “open” as the command and specify the path to the application in the arguments section.
You can then double-click that object in the navigation panel to launch the specified application.
Hope that helps!
Cheers,
Felix
Hello team, maybe it is possible to allow “re-parent” with disable system integrity protection on Mac?
It will be an option for advanced users for example..
Or it is not possible ? only thoughts )
Hi there! No, we looked into this before SIP was even a thing. I’m sorry to say but as far as I know there’s just no way to do this on macOS. Cheers, Felix
