I just implemented this (will be available in the next V6 beta release):
Clicking an individual item will just pre-fill the regular expression and lets you modify/add it yourself.
Clicking on “Add all from Category” will add all the regular expressions from the category into the list with default colors. You can simply modify the entry by clicking on “Remove” which populates the regular expression and color form fields, then add it again.
Clicking “Add all from all Categories” will add all the available regular expressions to the list:
Here’s the list I implemented:
NETWORKS
Matches IPv4 addresses
\b(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\b
Matches IPv6 addresses
\b(?:(?:(?:[A-F0-9]{1,4}:){6}|(?=(?:[A-F0-9]{0,4}:){0,6}(?:[0-9]{1,3}\.){3}[0-9]{1,3}(?![:.\w]))(([0-9A-F]{1,4}:){0,5}|:)((:[0-9A-F]{1,4}){1,5}:|:)|::(?:[A-F0-9]{1,4}:){5})(?:(?:25[0-5]|2[0-4][0-9]|1[0-9][0-9]|[1-9]?[0-9])\.){3}(?:25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)|(?:[A-F0-9]{1,4}:){7}[A-F0-9]{1,4}|(?=(?:[A-F0-9]{0,4}:){0,7}[A-F0-9]{0,4}(?![:.\w]))(([0-9A-F]{1,4}:){1,7}|:)((:[0-9A-F]{1,4}){1,7}|:)|(?:[A-F0-9]{1,4}:){7}:|:(:[A-F0-9]{1,4}){7})(?![:.\w])\b
MAC Address
\b([0-9a-fA-F]{2}:??){5}([0-9a-fA-F]{2})\b
localhost
\b(?i)localhost\b
Color
#FF4DFF
#000000
INFO
Matches Email
^((\w+([-+.]\w+)*@\w+([-.]\w+)*\.\w+([-.]\w+)*)\s*[;,.]{0,1}\s*)+$
Matches International Phone Number
^\+(?:[0-9] ?){6,14}[0-9]$
Matches URL
^(https?|ftp|file)://.+$
XML Tags
</?([A-Za-z](?=([^\s>/]*))\2)(?=((?:=\s*(?:"[^"]*"|'[^']*'|[^\s>]+)|[^>])*))\3(?:>|$)
Matches Info Message
\b(?i)last (login|failed login)\b|\b(?i)info(?:rmation)?\b|\b(?i)(transmitted|received)\b
Color
#54CCEF
#000000
WARNING
Matches Warning
\b(?i)warn(?:ing)?\b|\b(?i)not (found|supported|permitted|allowed)\b|\b(?i)connection (refused|closed)\b|\b(?i)disconne(ct|cted|cting)\b|\b(?i)(refused|stopped|exited|unknown|unsupported)\b|\b(?i)expire(?:d)?\b
Color
#FFC000
#000000
SUCCESS
\b(?i)(up|listen|accepted|session opened)\b|\b(?i)enable(?:d)?\b|\b(?i)y(?:es)?\b|\b(?i)succe(ss|ssful|ssfully)\b|\b(?i)conne(ct|cted|cting)\b|\b(?i)establish(?:ed)?\b|\b(?i)activ(e|ated)\b
Color
#18ED93
#000000
FAILED
\b(?i)(root|down|shutdown|denied|problem|notconnect|connection timed out|permission denied|authentication failure|session closed|packet loss|inactive)\b|\b(?i)n(?:o)?\b|\b(?i)disa(ble|bled|llowed)\b|\b(?i)fa(il|iled|ilure|ult|ulted)\b|\b(?i)er(r|ror|rors)\b
Color
#FF6060
#000000
