Add Notes
It would be nice to have an add notes option.
We now have Tasks :wink: but notes would be nice to keep extra info;
Such as:
DiskStation	10.0.170.5
Netgear1	10.0.170.2
Netgear2	10.0.170.3
Bedroom	10.0.170.23
Livingroom	10.0.170.10
Or other notes ofcourse
Forgot the Screenshots (Remote Desktop Manager has these options):
Yes we can add notes to the connection, but they are not easy to open / view in a quick way.
So best option; if you click on a Note it will show like a connection :wink:
Maybe also add an Markdown / html / RTF etc. option for notes so they can be displayed in a nice way when opened.
Hey Kay,
for the next major release we plan to add a new generic object type which will allow you to store just custom properties and notes.
“but they are not easy to open / view in a quick way”: Yes they are! Just add the “Notes” item to your toolbar.
we’re happy to announce that the first beta of Royal TSX 5.0 is now available and includes a new object type: “Information”.
Please let us know if that suits your use case!
You can get the beta here: https://royalapps.com/ts/mac/features-beta
it’s not ideal. a notes window should be per connection + docked off to the right side of the window. having it as a popup box that blocks interaction with the connection makes this feature next to useless, atleast for me personally.
@Rapha Have you tried dragging the popup to undock/float it? Does that work for you?
i just tried, and okay, that’s one step in the right direction :slight_smile: but i still am only able to edit any info/notes when the connection settings dialogue is open, so.. yeah. if this would be kind of a sticky note where you can just leave it open and add stuff like with markup or plaintext, then it would be nice. thanks for the quick answer tho! :slight_smile:
Hey Rapha! Glad that helped at least a little. Currently it’s not possible to edit notes directly in the popup. If you want us to add that feature in a future version, I guess it’s best to create a new feature request in this forum. Cheers, Felix
