Action section loses focus on rdp disconnect
V6 introduced this annoying bug.
If i have two rdp or more connections open and log off on one server and then switch to the other connected server the Action section loses focus or doesn’t fully work anymore.
This seems to happen when another session/tab closes and i have another tab active.
I have to switch to another open tab and then switch back to get the Actions section fully working again.
Hi Petrus,
could you please create a new support ticket here:
and attach screenshots of the Display Options as well as the Window Mode settings of your connections?
Furthermore, it would be helpful, if you could also upload a video of the effect happening, so I can try to reproduce this behavior.
Thanks and best regards,
